87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room Schedule with Color Field
Wed, May 27, 2009 at 9:09:06 PM | Room Schedule with Color Field
LMD3
Is it possible to create a room schedule with a field that shows the colors for each room?  Basically, I want to input the colors from the color legend into the room schedule.  Thanks.
Thu, May 28, 2009 at 4:36:10 AM | Room Schedule with Color Field
tim123
4 Stars: 19 Votes
I don't believe that you can do this automatically.  You can do it manually in a drafting view and overlay it on the schedule.
Thu, May 28, 2009 at 8:25:02 AM | Room Schedule with Color Field
LMD3
How do I overlay the drafting view in a schedule?  Revit won't allow me to copy and paste the drafting view into a schedule.
Thanks.
Thu, May 28, 2009 at 9:27:00 AM | Room Schedule with Color Field
tim123
4 Stars: 19 Votes
You can do it in a sheet view.  Activate the drafting view and line up the fill patterns with the schedule.
I would not do this though unless there was really a good reason to, particularly if there are many rooms as it will not update with the schedule if you change something and may inadvertantly lead to errors.
Adding Phase Created to Room Schedule
Fri, Sep 9, 2016 at 11:29:03 AM
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:52 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:51 AM
Room Schedules
Tue, Feb 18, 2014 at 9:31:13 AM
Revit 2016 Room finish schedule and material schedule
Thu, Mar 9, 2017 at 3:41:42 PM
Page generation time: 0.6816
