52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> MAX to Revit Roof
Wed, May 27, 2009 at 3:21:22 PM | MAX to Revit Roof
ayuda
I've got a MAX (version 2010) NURBS surface I want to import into REVIT 2010 as a Roof. So far I've been able to bring it in using the method of importing the exported DWG file into a revit mass and then using the 'Roof by Face' tool to create my roof.
My problem is that my NURBS surface is triangulated when imported into REVIT and these become my selectable faces. So far I've only been able to select  about 5-8 faces maximum at a time and making separate roof chunks out of those. If I try to select more faces I get an error message.
Is there a way to do this so it is all one smooth roof instead of separate chunks? Any help is most appreciated!
Wed, May 27, 2009 at 3:26:50 PM | MAX to Revit Roof
4 Stars: 203 Votes
Can you please put here that "NURB surface in DWG to take a look??
Wed, May 27, 2009 at 3:34:34 PM | MAX to Revit Roof
ayuda
Sure. Here it is.
Wed, May 27, 2009 at 3:47:51 PM | MAX to Revit Roof
4 Stars: 203 Votes
Yeah, this is like a "Wire mesh", convert this in to a "Solid" instead a "Mesh"...
Wed, May 27, 2009 at 4:01:00 PM | MAX to Revit Roof
ayuda
You mean in MAX? Are you saying I should extrude it in some way and add thickness to it? If in CAD, I'm not very familiar with 3D CAD, would you mind telling me how I'd go about doing this?
Thu, May 28, 2009 at 3:32:35 AM | MAX to Revit Roof
4 Stars: 203 Votes
In Max (you create that in max, right?) convert that Wire mesh in ONE solid...
Thu, May 28, 2009 at 8:42:36 AM | MAX to Revit Roof
ayuda
This is already one solid in MAX, not wiremesh. Originally it was a NURBS surface then I edited it and collapsed my edits so it is currently an 'editable poly'. Here's my MAX file. Do I need to convert it to an editable mesh?
It seems like no matter what I convert it to in MAX once I export it to DWG format it still causes the same effect when I import it into REVIT.
Could you please clarify?
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:22 PM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:40 PM
Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Tue, Mar 31, 2009 at 10:15:40 AM
MAX TO REVIT?
Tue, Feb 10, 2009 at 8:38:48 PM
Page generation time: 2.2800
