51 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Creating a .pat from scratch
1 Posts No Rating |
Hello, I need to create some filled region patterns from scratch to match tile patterns we are using on a job. Everything I find seems to have a pattern created in AutoCAD as a starting point or importing a file. I don't even have it in AutoCAD and I can't find the pattern anywhere. Is there a way to create it within Revit? No short answers please, I will need a pretty good explanation if you have one! Thanks.
There is a pat file in the program folder with the definitions for the patterns, although for simple patterns you can do it directly in Revit. There is an explanation in the pat file on how to create the patterns. I created a pdf that explains it in more detail - I will try to dig this out.
Found it.
45 Posts No Rating |
Tim THANKS A BUNCH!!! I can't believe that I was that close to understanding how it actually worked. But that PDF cleared up ALL THE MUDDY parts. This was GREAT!!!
.Pat Files - Creating new hatch (fill) patterns... with letters (Fire ratings) |
Fri, Mar 19, 2010 at 11:58:57 AM
Creating Waal from scratch |
Tue, Dec 20, 2005 at 12:35:28 PM
creating tables from scratch |
Fri, Mar 27, 2009 at 11:41:06 AM
Inexperienced in creating families from scratch in Revit 2008... Help please??? |
Sun, May 2, 2010 at 5:00:11 AM
Import PAT File |
Tue, Dec 14, 2010 at 9:42:43 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
