32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Filter by Material
Wed, May 27, 2009 at 1:37:16 PM | Filter by Material
missgayley
missgayley Avatar
Hi All,
I use Revit Structure 2009  Cryingwill jump to 2010 for the next new project).
anyway ~ is there a way to add a filter by material??    for example, on my braced frame elevations, i only want to see the steel beams & columns, not the light gage or wood framing members .  as far as i can tell, the current filter only allows for filter by function.
i know i can click an item and "choose all instances", but then i have to pick every different sized hss or pipe.
should i move this to wishlist?? or is it out there somewhere???
thanks much,
missgayley
Wed, May 27, 2009 at 1:52:49 PM | Filter by Material
You can choose the types you want to see then isolate those.
Wed, May 27, 2009 at 2:08:10 PM | Filter by Material
missgayley
missgayley Avatar
which is how i do it now....
so there is no filtering option available to do this?
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:31 AM
How to filter by wall layer material
Tue, Feb 20, 2018 at 6:54:28 PM
Material Volume out of Material Takeoff
Sat, Aug 9, 2008 at 7:23:49 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:08 AM
Filter turns everything off
Wed, Apr 19, 2017 at 9:25:55 AM
Page generation time: 0.7881
