Forums >> Community >> Newbies >> Revit for Cabinets
1 Posts No Rating |
I am a cabinet maker. I currently use AutoCAD 2009 for my shop drawings in 2D. Is REVIT a good prgram to create DETAILED cabinet shop drawings and can i generate cutlists from this program? Any onfo would be appreciated. Thanks, James
It could work but there would be a good amount of initial investigating, and process development involved. You have to think about how it gets scheduled, how you want to "see" the model, etc. Its possible and it can do a very good job, if you put forth the initial effort.
----------------------------------- Chatting it up on gmail - travistlo.j@gmail.com |
There is a user named mflure who frequents the chat room. He's a nice dude who is really keen on Revit families and has been playing with some interesting stuff. Stop by RC chat from time to time to see if he's in and give him a shout.
qab
^_^
Debian + VirtualBox + Revit
there are cabinet makers on this forum that use Revit. hopefully one will reply to your post. i would say that Revit would be a great program for you.
6 Posts No Rating |
hey guys, im also a cabinet maker , from what i understand it is possible for me to create families of cabinets, my only concern is it possible to generate a list of the cabinet parts and its dimension?
thanks.
If each part is a seperate family, then yes you can but I would probably assemble it at the project level.
6 Posts No Rating |
what would this feature be called? If i make parametric cabinets with standard parts, gables , door, etc i would have to somehow break them up into individual family before i can do this?
thanks
In order for component families to schedule in a project, they have to be shared families that are nested in a host family or directly loaded into a project. You can't schedule from a family. Individual extrusions in a family will not schedule so that is why every nut, bolt, screw, piece of wood would have to be a seperate family if you want to schedule them.
If you are building these families for others to use in their projects - DON'T! We don't need families that have as many shared families as you are proposing. If this is just for your use, then your OK.
6 Posts No Rating |
I will do a bit more research and try to get a demo version to try. thank you
Cabinets only are inserting dashed |
Tue, Oct 26, 2010 at 10:25:29 AM
How do I add crown molding to wall cabinets? |
Mon, Sep 22, 2014 at 7:13:43 AM
Creating furr downs above cabinets... |
Fri, Jul 13, 2012 at 8:36:37 AM
Floor tile patters show under cabinets |
Sun, Mar 25, 2007 at 11:08:03 PM
Parametric Cabinets causing crash in RAC 2010 |
Tue, Aug 11, 2009 at 1:21:18 PM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
