45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> error message: Unable to split wall panel(s).
4 Posts No Rating |
I have a fairly extensive model of a house that has been developed over the last few months. Recently when trying to make some minor modifications like adding a stone trim layer to a compound wall family (rather than using a sweep), or re-aligning an interior roof edge to a wall I get the following message after the machine computes for about 5 minutes and I go through a few "accept" menus for items that need to be detached, dimensions lost, or constraints no longer satisfied: "Unable to split wall panel(s)." at which point I have to cancel the command. Anybody run into this before and have ideas what I can check, or what I need to detach, rework, etc. to get the model to perform? Thanks. This is my first post. I have been able to find the answer to most of my other puzzles by searching others' posts. RevitCity rocks!
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
you could add another wall, stone only adjacent to your existing wall this is what I do sometimes that it is easy to adjust around windows and such. Good Luck
"Unable to write to..." Error Message |
Mon, Sep 30, 2013 at 7:34:37 AM
error message, unable to open revit file |
Thu, Nov 6, 2008 at 9:12:12 AM
8 PANEL POCKET DOOR WILL NOT INSERT INTO PROJECT CORRECTLY -ERROR MESSAGE |
Mon, Aug 15, 2005 at 4:24:29 PM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:11 PM
Members: | 2018170 | Objects: | 22949 | Forum Posts: | 152183 | Job Listings: | 3 |
