77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing a family type (from door to window)
Tue, May 26, 2009 at 1:30:01 PM | Changing a family type (from door to window)
aaronkennedy
working in 2009.  I downloaded a "window" that was created as an other family.  I want to change it to a window so it shows up in my schedules and I can tag it in plans and sections.  Any advice?
 Thank you,
AAron
Tue, May 26, 2009 at 1:45:54 PM | Changing a family type (from door to window)
4 Stars: 202 Votes
Edit the family, go to Settings>Family category and parameters and change the categoty to Windows...
Tue, May 26, 2009 at 1:48:49 PM | Changing a family type (from door to window)
tim123
4 Stars: 19 Votes
You can't change it into a window.  You will have to remodel it or find another one.
One option is to create a different schedule for just those 'doors' and call it a window schedule.  Place it beneath (or in, by splitting it) your schedule for the proper windows.
Tue, May 26, 2009 at 1:51:46 PM | Changing a family type (from door to window)
tim123
4 Stars: 19 Votes
My apologies - Typhoon is correct.
Tue, May 26, 2009 at 2:10:07 PM | Changing a family type (from door to window)
aaronkennedy
Thank you very much.  Saved me some time!
AAron
Wed, May 27, 2009 at 7:24:26 AM | Changing a family type (from door to window)
MARS1276
1 Stars: 1 Votes
You CAN create a Door/Window schedule.  It's tedious with the naming of the parameters the schedule shares with the doors and windows both, but then you can also create a Hardware schedule for the doors alone as well.
Thread I posted how to do this is located here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=15209
And by the way, the Door/Window Schedule has to be a multi-category schedule.
Hope this helps!
Mon, Aug 18, 2014 at 8:59:57 AM | Changing a family type (from door to window)
jameslacson
You have to have it remodeled as there is no way to edit and or changing an of it,
-check me at http://caldwells.com/-
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:29 AM
What type of window are these????? HELP~~
Sun, Feb 19, 2012 at 2:47:54 AM
Changing Family Types
Thu, Nov 20, 2008 at 2:56:12 PM
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:11 PM
Multi Panel Sliding door that is actually a Window Family
Fri, Feb 20, 2009 at 7:22:05 AM
Page generation time: 1.3145
