56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walling
Tue, Jul 19, 2005 at 9:35:28 PM | Walling
Shanzie
Guys/girls, When you draw a wall (110 brick / 50 cavity / 90 timber framing all in one) and have a ceiling height of 3000mm with a overhang of 600mm. When you take a section through the wall, both brick and stud framing go up to roof height, now is there a way you can edit the brick work to stop at say 2700mm and the stud framing to 3000mm??? Thanks like always!! SHANZIE
Wed, Jul 20, 2005 at 12:30:43 AM | RE: Walling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Two ways: Using a stacked wall, OR unlocking the top of the brick wall layer and then using the top extension distance parameter to define the offset distance... (this is probably the easier option, as stacked walls can be fiddly). Select the composite wall, Go to properties-->Edit-->Edit Structure-->Switch Preview to section-->Choose modify-->Pick top edge of brick and unlock the padlock. Click okay until you've gotten rid of all dialog boxes. In the walls instance properties there should now be an available field for Top Extension distance... Set this to -300 or as required. HTH.
How to cut curtain walling and make a sloped wall?
Sun, Nov 20, 2011 at 2:42:37 PM
Curtain wall issues
Wed, Nov 25, 2015 at 9:54:38 AM
Curtain Walling on an Angle
Fri, May 20, 2011 at 11:07:09 AM
curtain walling single door
Mon, Mar 6, 2006 at 2:12:51 PM
Tags help please
Thu, Oct 23, 2008 at 3:48:48 AM
Page generation time: 1.8861
