Forums >> Revit Building >> Technical Support >> Importing views from other revit projects
30 Posts No Rating |
Hi guys, Im using 2010 and i have two seperate files. in one of the files i am setting up drawing sheets and want to add some views from the other project. what is the best way to do this?? Ive tried all the export to options but none of them will seem to insert. please help? thanks.
p.s its 3D perspectives that i need to import
Hi, i don't have here the Revit but try this, create a "Drafting View" then in that view go to "Import>Revit file" or "import> revit Views", choose what you want.... Like i told you i don't have revit here right now and i don't have sure about the "real" name for that....
You don't say if this is an image but I will hope it is. If it is a 3D view, then you need the whole model. If it is a rendered view, save it out of the original file as a jpg and import it. You can also export 2D or 3D views to CAD and then import those as a 2D detail view.
using views in other revit projects |
Sun, Nov 21, 2010 at 2:23:26 PM
importing families to projects |
Sat, Nov 15, 2008 at 10:31:45 PM
Views in Families and Projects |
Fri, Sep 28, 2012 at 11:12:14 AM
exporing detail view, drafting views, + legend views to other revit projects 9.1 |
Thu, May 3, 2007 at 4:33:32 PM
Remove Working Views from Revit Projects with Python Shell Script |
Mon, Mar 25, 2013 at 12:43:53 PM
Members: | 2105101 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
