69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Download family but no rendering
Mon, May 25, 2009 at 5:55:45 PM | Download family but no rendering
PrinceRevit
Hello,
I downloaded some families at RevitCity but when I wanted rendering my project these families are just white.
I tried to edit these families and changed the elements properties but when I downloaded the edited families in my project , they are white.
How can I modified the elements properties of these families?
Family example: Double_Barn_ Door_2211
(excuse me for the grammar I am french)
Thank you
Mon, May 25, 2009 at 9:53:20 PM | Download family but no rendering
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Comment allez-vouz mon ami?...look, open your family file and go to Settings-->Materials... and there just pick "Replace" button and change its materials i.e. "Clear Yellow Pine" for one of the Render Appearance Library materials (See attached). This happens because your door was made in an earlier version of Revit. J'espère que cela vous aide....au revoir!!!!...
Mon, May 25, 2009 at 11:09:45 PM | Download family but no rendering
PrinceRevit
Thank you for answering me.
I have already done you said but it is still white. You told me that happens because this family  was made in the earler version of Revit, does that mean I can never change the materials for the rendering?
another question:
When I downloaded Landscape_rock_15 is the same. it is still white. but on te Gallery of RevitCityit it appears with numerous colors. And when I go to the file family they are no materials.
Thank you for you help
(you speak french very well)
Mon, May 25, 2009 at 11:30:20 PM | Download family but no rendering
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Well, if you have already loaded this door into your project, change the material there (I mean in your project file not in the family file, this because you have it already loaded). "You told me that happens because this family  was made in the earler version of Revit, does that mean I can never change the materials for the rendering?", of course you can, just open your family files and assign the new materials in the Materials Dialogue box and save before you load them into a project. Do it even with the rock_15 you are talking about. Merci mon ami, Je veux practiquer mon français un peu...
Tue, May 26, 2009 at 12:23:21 AM | Download family but no rendering
PrinceRevit
Excuse me but I am a Newbee.
I Have Revit2010 now.
so I'm in my project.
1/ I clic on  my Double_Barn_ Door_2211 in my  first plan view or 3d view
2/ I clic on "edit Family"
3/I am in family file. I click on a element of my family
4/I clic on "Instance properties" and clic on the row "clear yellow pine ... "
5/ materials box  appears. I clic "apparence" and "replace" by "Wood Elm Burl Stained Light No Gloss" for example.
6/ I apply and say OK
7/ I load this family in my project
8/ I chose " overwrite the existing version and its parameter values"
9/I "rendering", and it is still write.
 Did I do something wrong?
pas  "pactiquer" mais pratiquer sans le "c".
Tue, May 26, 2009 at 3:35:12 AM | Download family but no rendering
4 Stars: 201 Votes
In your Project go to Materials and find that material "clear yellow pine", check if it have the right material you want....
Tue, May 26, 2009 at 7:45:38 AM | Download family but no rendering
PrinceRevit
Thank you very much Erland73 and Typhoon. It works now because I founnd "Manage" and "materials" in My project
My door is finally not white in my rendering.
Yehoo I'm so happy!
Tue, May 26, 2009 at 9:20:28 AM | Download family but no rendering
erland73
erland73 Avatar
4.5 Stars: 85 Votes
De rien mon ami.......
Family Download affecting other parts of drawing
Mon, Jan 3, 2011 at 6:24:16 PM
Dont know how to download families
Wed, Jan 31, 2018 at 11:50:15 AM
12
Revit 2019. Component, loading/finding/download family.
Fri, Mar 27, 2020 at 8:05:26 AM
cannot download drawings from revitcity
Sun, Jun 25, 2017 at 2:02:49 AM
Download Revit 2010 Now!!
Mon, Oct 12, 2009 at 10:42:37 AM
Page generation time: 2.2543
