53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Domed Roof not showing
Mon, May 25, 2009 at 9:54:04 AM | Domed Roof not showing
jdivina
HI,
So i was wondering if anyone knew the answer to my problem here.
 im trying to show the roof in this east elevation but it doesn't show.
the floor plan shows where the elevation is being seen at and its at the same spots for the south and north elevation and you can see it in there.  but for the west and east elevations it doesn't show at all.
the visual setting is on and everything that supposed to be on is on.
Does anyone have any info on how i can fix this.
Thanks
JD
Mon, May 25, 2009 at 9:55:57 AM | Domed Roof not showing
jdivina
Sorrry that didn't work here is a jpg of the problem
JD
jdivina
JD
Mon, May 25, 2009 at 10:10:01 AM | Domed Roof not showing
tim123
4 Stars: 19 Votes
The image does not show how far the depth of the elevation extends - is the view depth sufficient to see the dome? (I't the dotted line with the stretch arrow.)
Mon, May 25, 2009 at 10:13:31 AM | Domed Roof not showing
jdivina
ohh
where can i find or view the dotted line with the arrow.
i only have the blue line when i click on the arrow from the elevation marker.
and i can move that but if its the blue line its right in front of the building.
like if i put the blue line in the middle of the building it shows a section instead
but the blue line is right in front of the building
JD
Mon, May 25, 2009 at 10:17:12 AM | Domed Roof not showing
jdivina
so when i was reading your idea
i checked my view depth on my view properties.
it seemed to show the roof now
when i changed the view depth to clip with line and changed the value to  a certain n umber.
thanks for the help
it took me awhile just to get to that point.
JD
Mon, May 25, 2009 at 10:23:39 AM | Domed Roof not showing
tim123
4 Stars: 19 Votes
You can adjust that in the view properties or in a plan view - see image (I can't see which version of Revit you're using though).
Mon, May 25, 2009 at 10:29:34 AM | Domed Roof not showing
jdivina
i am using the 2009 version.
it doesn't seem like we have that dotted line
or i just don't know how to get it
JD
Mon, May 25, 2009 at 10:38:48 AM | Domed Roof not showing
jdivina
nevermind i found the dotted line
thanks for the help
JD
Mon, May 25, 2009 at 10:50:38 AM | Domed Roof not showing
tim123
4 Stars: 19 Votes
There's no dotted line if the Far clipping is set to 'No clip', but then you should see everything in the elevation.
Domed Roof
Mon, Aug 16, 2004 at 7:06:12 PM
Unable to Create Domed Roof
Thu, Jan 8, 2009 at 11:31:53 PM
Creating Domed Roof
Tue, Oct 9, 2007 at 12:06:36 PM
Creating domed roof light - mullion problem
Thu, Jul 15, 2010 at 1:26:04 PM
Domed roofs
Thu, Dec 22, 2005 at 5:36:33 PM
Page generation time: 0.6310
