79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Min Height formula not working :(
Sun, May 24, 2009 at 1:00:48 AM | Min Height formula not working :(
muffles
I've been searching the forum and can't find anything on this, so maybe someone out there has an answer inside their head for me -
I'm kind of new to using formulas (so it could be something obvious I'm missing), although I've made bunches of basic families.  Right now I'm attempting to add a Min Height parameter to a family.  This is the formula I'm using:
if(or(and(Min Height<10", Min Height >100'), or(Min Height=10", Min Height=100')), Min Height, if(Min Height<100', 100', 10"Winking)
I get an error message saying I have a circular chain of references.  Any thoughts on how to fix this?
Sun, May 24, 2009 at 9:23:00 AM | Min Height formula not working :(
tim123
4 Stars: 19 Votes
Can you explain what you trying to achieve?  It would appear that for a Min Height parameter you would just need:
if (Min Height<10", 10", Min Height)
You receive that error message if you are including the same parameter in the formula as the parameter itself, eg
Min Height = Min Height + 10, or
Min Height =if (Min Height<10, 10, Min Height)
Sun, May 24, 2009 at 9:37:33 AM | Min Height formula not working :(
coreed
coreed Avatar
4 Stars: 16 Votes
your formula contradicts itself. if you can state how you want this formula to function in terms of Min Height we can come up with something a lot cleaner i think.
it looks like you want Min Height set to 10" if someone enters a value less than 10" or greater than 100'. anything that equals 10" to 100' will be accepted as Min Height ? if that is the case, then this formula should work.
 If ( or( Min Height <10", Min Height > 100'), 10", Min Height)
hth
Edited on: Sun, May 24, 2009 at 9:40:31 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, May 24, 2009 at 8:48:15 PM | Min Height formula not working :(
muffles
Thanks guys.  This is starting to make sense.  My family is a hanging canopy, and I want it to have a minimum height of 10" below the ceiling, and a max of 100' below.
Sorry for the errant smiley in my previous post.  That was not supposed to be there.
Mon, May 25, 2009 at 7:48:50 AM | Min Height formula not working :(
tim123
4 Stars: 19 Votes
Try this one:
=if(Length < 10", 10", if(Length > 100', 100', Length))
Mon, May 25, 2009 at 9:36:22 AM | tim123
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting tim123 from 2009-05-25 07:48:49
Try this one:
ditto
=if (Min Height < 10", 10", if (Min Height > 100', 100', Min Height))
Edited on: Mon, May 25, 2009 at 9:40:47 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, May 27, 2009 at 6:53:48 PM | Min Height formula not working :(
muffles
Thanks so much you guys!  It makes a lot more sense now.  I appreciate the help!
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:50 AM
14
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:17 AM
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:52 AM
Volume formula issues
Mon, Jul 7, 2008 at 8:44:10 AM
label parameter formula
Thu, Apr 26, 2012 at 12:15:04 PM
Page generation time: 0.5500
