91 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> compound slab or roof slopes
Fri, May 22, 2009 at 2:39:16 PM | compound slab or roof slopes
KickingWater
I've "searched" this topic but it seems most answers are that it's not worth it to model compound slab/roof slopes (sloping more than one direction).  That may be fine for construction documents, but I'm modeling a structure to a high level of detail for use in clash detection in Navisworks, so I need to know exactly where my slabs are.
 Is there a way to model a "flat" roof of multiple ridges and valleys and varying spot elevations?  I've run into the same problems others have with slope arrows in that I can only slope in one direction.  I would even create separate triangular planes and join them if I could figure out how to slope them in both the x and y directions.
KickingWater
Fri, May 22, 2009 at 2:51:11 PM | compound slab or roof slopes
KickingWater
After posting I read "Auditorium Floor with multiple slopes"  Thanks!  I think with the Options Bar / Define Points knowledge I'm well underway.  Finally.
KickingWater
Fri, May 22, 2009 at 2:56:47 PM | compound slab or roof slopes
tim123
4 Stars: 19 Votes
I would use a floor to do this.  You can edit the levels quite finely and in specific places using reference planes. Click on the floor and modify sub-elements.
Tue, May 26, 2009 at 2:35:05 PM | compound slab or roof slopes
KickingWater
Tim,
I did end up using a floor slab.  It works pretty well, except that the program tends to put some ridges/valleys in places I don't want them.  But I think it will do the trick. Thanks.
KickingWater
Tue, May 26, 2009 at 2:45:16 PM | compound slab or roof slopes
4 Stars: 203 Votes
the trick is ...
Tue, May 26, 2009 at 4:20:49 PM | tim123
travistlo
5 Stars: 2 Votes
Quoting tim123 from 2009-05-22 14:56:47
"I would use a floor to do this.  You can edit the levels quite finely and in specific places using reference planes. Click on the floor and modify sub-elements."
Why use a floor? when a roof can do the same thing? I think from a technical standpoint the roof and floor are identical, other than the roof is a roof, and the floor is a floor.
As a tip, I found that its easier to use multiple roofs to get the correct ridges and valleys. You can use the join geometry tool to make them act more like 1 object. I make 1 roof that has the main ridges and valleys, then use smaller roofs for crickets.
Chatting it up on gmail - travistlo.j@gmail.com
Wed, May 27, 2009 at 7:17:19 AM | compound slab or roof slopes
MARS1276
1 Stars: 1 Votes
Look into AutoCAD's site for Revit tutorials.  Which version are you using?  I have found a page for 2010 that has 6 or 7 downloads available that are essentially templates that you use with the tutorial.  One of them has a tutorial on how to do the exact thing you are asking about... for Roofs.  So take a look into that and like others have mentioned; think outside the box and use a roof for your floor slab.  Hope this helps.
The files you are looking for are:
TutorialsArchitectureImpENU.chm
rac_tutorial_datasets_01_i.zip
rac_tutorial_datasets_02_i.zip
rac_tutorial_datasets_03_i.zip
rac_tutorial_datasets_04_i.zip
rac_tutorial_datasets_05_i.zip
rac_tutorial_datasets_06_i.zip
rac_tutorial_documents_i.zip
Wed, May 27, 2009 at 7:19:30 AM | compound slab or roof slopes
MARS1276
1 Stars: 1 Votes
Edit: Forget what I said about using a Roof for a Floor slab; while it can be done, this tutorial shows you how to create flat roofs with slopes towards point (drain or what have you).
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
Multiple sloping slab on grade
Wed, Sep 28, 2005 at 11:20:27 PM
roof issue (even roof valley slopes with uncentered drain locations)
Wed, Mar 14, 2012 at 12:25:14 PM
slab with 2 slopes
Wed, Apr 15, 2015 at 9:22:17 AM
Page generation time: 0.6545
