48 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Need Tag Help
28 Posts No Rating |
I have a structural column tag that I am trying to modify. My problem is that I am not fully understanding why the parameters that I have selected are not allowing me to edit them when in plan view. What I need is the ability to manually specify the load by just typing it in on either the top or bottom of the column type (depending on clarity) Currently I have the comment parameter on the bottom of the tag because it is the only thing that I have found to work. In a perfect world I would like to create two instance parametes, one for the top and one for the bottom, rather than the "comments" parameter provided. Attached is the file I am working on. Any help would be much appreciated.
Read the HELP on shared parameters. You can add shared parameters to your tag that will allow you to do what you want but you must have the shared parameter defined first.
Keynote Tag defaulting to Category Tag |
Fri, Jul 20, 2018 at 11:20:17 AM
Can not tag beams |
Fri, May 8, 2009 at 6:51:36 AM
Place tag by clicking object then tag location |
Thu, Oct 18, 2012 at 7:17:17 AM
Material tag and doors |
Mon, May 29, 2006 at 5:04:07 PM
Custom Section Tag Rotating Lines |
Tue, Jul 31, 2007 at 1:23:42 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
