50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Lighting fixtures that do not select with drag box selection
Thu, May 21, 2009 at 12:43:31 PM | Lighting fixtures that do not select with drag box selection
iREV
3.5 Stars: 3 Votes
I have lighting fixtures in a project that will not select when I drag a box around them, but will select individually. I do not have design options or any other special treatment for these instances.  Does anyone know what the problem is?
Thu, May 21, 2009 at 12:57:11 PM | Lighting fixtures that do not select with drag box selection
3.5 Stars: 397 Votes
If you can select individually by pointing then for some reason, the family is probably built larger than what you see and you don't have the whole family in your window.  Window a larger area and see what happens.  Could also be part of a group.
Selection Box Doesn't Include Ceilings
Tue, Jan 8, 2013 at 3:51:20 PM
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:38 PM
create a new lighting fixtures
Fri, Aug 15, 2008 at 10:54:54 AM
Copy/Monitor - Lighting Fixtures
Thu, Dec 15, 2011 at 4:27:11 PM
Lighting Fixtures
Thu, Apr 24, 2014 at 6:13:26 AM
Page generation time: 1.2435
