51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> excessive polygons
95 Posts No Rating |
Hello, I just downloaded a toilet family from the Kohler website (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=10452802§ion=2&category=30&subcategory=22), which would be great if it didn't show so many polygons... Is there a way to make this look more like a normal drawing? I've had this issue before, and decided to go with a generic model instead, but I'd like to find out if there is an actual solution. Thanks
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer |
Anything modeled outside of Revit is usually done as polygons. If you don't want those showing in plan or elevations, then edit the family adding 2d detail lines (masking regions) and turn the 3d off in plans and elevations ... probably sections too.
thanks Hub, I don't want to sound like I'm complaining, but one could hope these families, provided by an established company such as Kohler, would be ready for immediate use.
using RAC-2013
Revit 2018.2 Print to PDF Turning Curves into Polygons |
Tue, Apr 17, 2018 at 12:30:39 AM
Counting Polygons and Vertices in Revit family object |
Fri, Sep 10, 2010 at 2:40:28 PM
Does Revit Render to 2D Vector? |
Fri, Dec 13, 2013 at 6:52:44 PM
DWG triangles to 4 sided polygons |
Sat, Aug 14, 2010 at 12:18:19 AM
Your dream computer setup for rendering in Revit? |
Fri, Nov 2, 2007 at 9:41:24 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
