48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can't find building elvations
Wed, May 20, 2009 at 10:11:21 AM | Can't find building elvations
Sparhawk
I am relatively new to Revit.  I have been working on a model and have lost the building elvations.  Using ZE on the any elevation view only displays a blank area.  I originally imported a cad file of the floor plan and I suspect this caused the problem.  Does anyone know how I can find them?
Wed, May 20, 2009 at 10:46:32 AM | Can't find building elvations
4 Stars: 203 Votes
Your CAD file probably have elements in the drawing, very fare away, my advise is write ZA, then select by crossing the all screen, go to the filter and "unselect all" and leave only the "Cad object", delete them, again ZA, now you probably will see your project with your elevations marks, go to the DWG file and check it, delete the problematic elements then import to REVIT...
Wed, May 20, 2009 at 10:56:58 AM | Can't find building elvations
Sparhawk
Thankyou!  Now I can see the biulding elevations and the elevation markers, but they are in different locations.  Should I drag the building to the markers or drag the markers to the building?
Wed, May 20, 2009 at 12:30:17 PM | Can't find building elvations
4 Stars: 203 Votes
LOL, tell me, what is more easy??? move the whole building OR move ONLY the elevation markers?
Wed, May 20, 2009 at 2:14:08 PM | Can't find building elvations
erland73
erland73 Avatar
4.5 Stars: 85 Votes
LOL, "if the mountain does not come to you....."
Wed, May 20, 2009 at 2:56:51 PM | Can't find building elvations
Sparhawk
Moving the model caused lots of problems.  I exteneded and trimmed the elevation markers to align with the model and it seems to be working.  Thank you for your advice.
Wed, May 20, 2009 at 4:37:00 PM | Can't find building elvations
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Well done, that's the idea, to find the best way by oneself......
Can't find precast concrete wall tees in Revit Structure 2012
Thu, Mar 15, 2012 at 9:53:47 AM
shadows on elvations
Tue, Dec 21, 2004 at 7:50:10 PM
Can't find ''Rectangle Panel - MPK''
Thu, Apr 3, 2014 at 5:50:24 AM
Sloped inscribed building pads have topo 'walls'
Wed, May 6, 2015 at 7:25:40 AM
ORIGO how to find
Thu, Jul 1, 2004 at 7:23:00 PM
Page generation time: 0.9252
