45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> lines in wall elevation
49 Posts No Rating |
I've noticed that when I look at my elevations between floor lines there is a line that is formed. I eliminate this line by the "join" command, but there are other instances like when the one wall abuts another and a verticle line is formed I cannot always "join" that line away and I end up with this line in my elevations. Is there a work around and why is this happening?
![5 Stars: 2 Votes](/images/stars_5.gif) |
simple wall should join and not show that line unless: They are different materials, or they are not coplaner. There can be many more factors but with the limited amount of information, you get a limited answer, hope it helps.
----------------------------------- Chatting it up on gmail - travistlo.j@gmail.com |
How to create wall panel lines to appear in elevation drawings? |
Sun, Jul 10, 2016 at 12:36:27 AM
Lines from different wall types showing up in elevation |
Tue, Sep 24, 2013 at 10:07:46 PM
Undesired Lines in Elevation |
Wed, Sep 12, 2007 at 11:38:24 PM
Elevation lines |
Tue, Oct 25, 2011 at 3:28:26 PM
Symbolic lines in elevation |
Thu, Jan 10, 2008 at 7:12:53 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
