Forums >> Community >> The Studio >> Radiation troubles
3 Posts No Rating |
Hello, ive had Revit 6.1 for some time, but only self teach occasionally. I am having trouble radiating my interiors to raytrace. I have 1 1/2 gigs of ram and a p4 3.0 processor. My raytrace takes forever, and raytracing even longer. Is this usual or do i need to change some settings to make it more efficient? Thanks in advance for any help!
Rendering does take a long time to render, some things to keep in mind the more complex the model the longer it takes to render, if you can avoid adding to much detail information to you model and apply textures, then Revit has less things to caluculate. What size are your image, and resolution. If you can cut down on some of that, it will increase your rendering time.
One thing to look at for your system, is your Video Graphics Card, sometimes increasing the memory or the type of card you are using might help increase your rendering time, but don't count on a significant change. Hopefully this help.
90 Posts No Rating |
For rendering it will help only procesor and memory. I don't know what is it 'forever' for you.
How much big image you make, how much details, how much lights. Lights kills rendering.
For example for one interior of restorante, with ~20 lights, on 2k was about 1-2 hour, radiosity and raytrace on good settings ... if you use his trees, delete it now.
Hello, new user troubles |
Tue, Jul 11, 2023 at 5:59:30 AM
Fire Place Troubles |
Thu, Jan 16, 2014 at 7:48:37 AM
Linked Door Schedule? |
Mon, May 30, 2011 at 4:25:48 AM
Download troubles |
Mon, Aug 2, 2004 at 11:46:12 AM
stacked wall troubles |
Tue, Feb 13, 2007 at 2:47:36 PM
Members: | 2115099 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
