22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Retrim internal door Revit 2009
Tue, May 19, 2009 at 6:54:33 AM | Retrim internal door Revit 2009
2005Mark
3.5 Stars: 2 Votes
Hi
I am doing a Loft conversation for a client and as I insert a door, part of it is outside the roof line. How do I retrim or cut the door the same slope as the roof. It is more or less from its top left corner down at 30 degrees.
Thanks
Mark
Tue, May 19, 2009 at 7:26:13 AM | Retrim internal door Revit 2009
3.5 Stars: 395 Votes
When you have special instances like this, you sometimes have to create special families.  You could modify your door family for this one instance and save it under a different name.  In the family, you could modify the trim, or delete the trim and add it in the project.  There are other ways too, but these are the easiest.
Rendering And Light Settings Revit 2009 [ 1 2 ]
Tue, Oct 20, 2009 at 3:06:23 AM
26
Wrapping Door Frames and Internal Door Frames [ 1 2 ]
Mon, Aug 11, 2008 at 11:02:26 AM
15
Internal Elevation Views in 2009
Thu, Sep 11, 2008 at 6:30:05 PM
Revit Internal Parameters..?
Tue, Sep 14, 2010 at 10:51:15 AM
How to Print Large Door Schedules Revit 2009
Wed, Jan 21, 2009 at 12:28:45 PM
Page generation time: 7.3212
