78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Simple dynamic window
Mon, May 18, 2009 at 2:54:19 PM | Simple dynamic window
Jorgensen
Hi
I'm a architet who normaly model in Sketchup. I find Revit interesting and would like to start sketching in this program, and then later move the model to Sketchup to make adjustments and render in VRay.
What I miss, is a very simple window, where the frame is 50mmx120mm, and the glass with only one face, it increases rendertime a lot, if it's 3d. And I would like to be able to click on the window and pull the width and height by using the mouse.
Does anyone know if it's possible and can someone help ?
Thanks in advance :-)
Jorgensen
Mon, May 18, 2009 at 5:17:11 PM | Simple dynamic window
jarosa
jarosa Avatar
4 Stars: 5 Votes
Windows are manipulated in the properties dialog boxes. Part of workin in Revit is creating families that fit the type of work you do. Once you commit to using this software you will find you can get it to do some powerful rendering. Most use Revit exclusively from dd to cd to rendering. Rendering time is an issue with larger files, but the quality is very good.
Storefront Window Panel Dynamic Length?
Fri, Jun 30, 2006 at 1:43:16 PM
Simple Dynamic Family
Fri, Nov 21, 2014 at 12:13:16 PM
Dynamic Annotations (detail callouts)
Fri, Jul 21, 2017 at 6:11:21 AM
Dynamic View problems
Fri, Oct 13, 2006 at 7:16:10 PM
Dynamic Weld
Mon, Feb 24, 2014 at 7:24:17 AM
Page generation time: 0.9647
