Forums >> Revit Building >> Technical Support >> export to cad lineweight issue.
Mon, May 18, 2009 at 10:33:35 AM | export to cad lineweight issue.
line
Hi      Does anyone know how to set a export lineweight as 0?      I have problems that my line around the views are exported and I have to manually turn them off.     I have made a screencap of the issue to clarify what i am looking for.       I know i can turn them off but I have the same issues with other element that i dont want to export but often use, like the reference lines.
thanks
Mon, May 18, 2009 at 11:44:26 AM | export to cad lineweight issue.
I don't see how you can set the lineweight to 0.
Our view window exports to a layer that is supposed to be set to no-plot, however, I see that when I open the file, the layer is set to plot though.  I would just set up a script file to run in acad to change that and turn them off.
We  don't have reference lines or reference planes on in our views so that they do not export.
Wed, May 27, 2009 at 9:51:17 AM | export to cad lineweight issue.
line
Thanks
Would have been easier if there was a hidden layer export.
I will try to setup the views as finished as possible instead.
Export to CAD - Colors
Mon, Mar 3, 2014 at 7:37:38 AM
Linked Cad - Global Lineweight
Wed, Sep 2, 2015 at 4:54:03 PM
Coordinating Lineweight of Revit to Cad
Fri, Dec 7, 2007 at 11:17:24 AM
I can“t export from revit to cad.
Fri, Jan 18, 2013 at 9:10:32 AM
(2015) import (link) CAD to Revit screened lines (lineweights)
Wed, Sep 30, 2015 at 2:20:54 PM
Page generation time: 0.7555
