Forums >> Revit Building >> Technical Support >> Floor Plan View
26 Posts No Rating |
I keep getting an error message as below
None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I find it annoying. I am obviously doing something grossly stupid. Can I shift a grid or two or is it a scale issue?
A homer simpson tip or two is required
Cheers
28 Posts No Rating |
Well, it depends on what you are trying to do. It usually has that message when something is turned off in a view, or the object is placed outside of the scope of the view. (Like with foundation walls, if you are drawing it from the level above where it shows up, it will put up that message.) I would check your visibility for that view, and check the settings on the tool you are using. But to be of any more elp, I would need to know what you are trying to do when you get the message.
Vanessa
I have the same problem where my walls aren't appearing in the floor plan but are appearing in the ceiling plan. The walls are attached to the floor & I have checked Visibility for walls. Can anyone help?
I worked out what my problem was. I had "Discipline" as "Structural" instead of 'architectural".
14 Posts No Rating |
I recently got this message and I thought that I had double-checked EVERYTHING. Then I discovered that a Worksets tab had been added to my Visibility/Graphics dialog. Sometimes Revit is just too smart and sneaky for me! Stephen
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN |
Fri, Aug 29, 2014 at 1:27:29 PM
RCP IN FLOOR PLAN VIEW |
Sun, Nov 2, 2008 at 1:32:31 PM
Floor Plan associated to wrong level... |
Fri, Jul 2, 2021 at 3:23:05 PM
Multiple sheets from same floor plan view with different scales? |
Fri, Aug 1, 2008 at 12:01:43 PM
copy & paste detail group from one plan view to another plan view (2017) |
Tue, Nov 29, 2016 at 4:57:42 PM
Members: | 2104026 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
