53 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> Grid Lines on an Angle - With Dimensions??
![SeanE Avatar](user_avatar/70119.jpg)
4 Posts No Rating |
All - I have a plan of a building that has a normal portion (with N/S-E/W walls) and one section that runs 45 degrees from it. I want a horizontal grid on all of it - and then vertical grids in two places for each of the sections: at 45 degrees for one area and 90 degrees for the other. I can put in the grids at angle OK - but the dimensioning won't read the angled measurement.... Any ideas?? Thanks, SeanE
4 Posts No Rating |
Never mind, I just figured it out... for the dimensions - the grids have to be parallel... for the grids to be parallel, you have the little visual indicators on the lines (the little -green?- dashes that appear). Thanks anyhow... SeanE
Grid Lines & editable dimensions |
Mon, Mar 30, 2009 at 6:11:38 PM
changing grid lines angle - walls are detached |
Fri, Apr 20, 2007 at 6:29:43 PM
Drawing Reference Planes in 3 Dimensions? |
Mon, Jun 2, 2008 at 12:07:55 PM
Grid lines moving together in different floor plans |
Mon, Sep 20, 2010 at 9:10:52 PM
disappearing grid lines |
Wed, Apr 19, 2006 at 5:44:48 PM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
