41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ceiling joist ends show above rafter line, how to trim?
Fri, May 15, 2009 at 1:56:31 PM | Ceiling joist ends show above rafter line, how to trim?
jbking
When using equal size rafters ceiling joists, the upper end corners of the joists poke above the rafter line.  This creates a line that shows up in the roof plan, elevations and 3d views.  How can I trim these corners off?
Mon, May 18, 2009 at 6:39:21 PM | Ceiling joist ends show above rafter line, how to trim?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
You can use void space to clip the corner off, or you maybe able to change the offset from the work point
Tue, May 19, 2009 at 1:37:43 PM | Ceiling joist ends show above rafter line, how to trim?
jbking
thanks, mbsteve, but correct me if I'm wrong, I don't think void sweeps work on elements like ceilings that aren't model families.  So far, the only way I've found to work around this problem is to move the boundary of the ceiling in from the face of framing far enough that the height of the joist corner is below the top of rafter line.  This work-around doesn't follow framing practice, and requires some clean up in the sections.  Any other ideas?
Tue, May 19, 2009 at 4:15:32 PM | Ceiling joist ends show above rafter line, how to trim?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I was thinking of using the void extrusion on the finished roof where the rafters punch through. Mr. Spot has a tutorial on void extrusions for stairs on curved walls to make the top of the walls follow the steps. I think that it might work. You can also turn off the joists in the elevation views.
Tue, May 19, 2009 at 6:33:41 PM | Ceiling joist ends show above rafter line, how to trim?
jbking
The void sweep does work, I just needed to use the cut geometry tool at the correct stage in the process of making the sweep.  Once I positioned the sweep below the roof sheathing line, no residual cut lines show up on the roof.  Thanks for your help.
Need Help Joining Rafter Ends in Revit Architecture 2009
Fri, Apr 10, 2009 at 11:09:58 AM
Sloped joist line type
Thu, Nov 25, 2010 at 12:25:03 PM
trim sweep for ceiling?
Fri, Jun 21, 2013 at 12:41:44 PM
Line Based Family Won't Join at Ends
Mon, Apr 10, 2023 at 8:13:58 AM
AAARRRGGGHH! Joist questions! [ 1 2 3 ]
Fri, Nov 18, 2011 at 9:13:39 AM
37
Page generation time: 1.0312
