Forums >> Revit Building >> Technical Support >> Cannot Select Elevation
7 Posts No Rating |
Hello, I am using Revit Architecture 2009, and cannot select elevation! I go to view->new->elevationBut elevation is not selectable (it isn't clickable). This may be because I started this project in Revit MEP 2009, then had to transfer it over to Revit Architecture. Still, how can I fix this problem?
7 Posts No Rating |
Also, sorry if this is in the wrong forum, I recently started using Revit and am a very confused person...If this is in the wrong forum where should I put this thread?
To create an elevation, goto a plan view, then pick elevation, place your pointer and adjust youe elevation width and depth. Now the elevation will be in your browser.
7 Posts No Rating |
Thank you,l but my problem is that I cannot select elevation. Here is a screenshot:http://img151.imageshack.us/img151/4811/fuuuuuu.png
![4 Stars: 19 Votes](/images/stars_4.gif) |
I don't think you're in a plan view.
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Yeah, according to your screeshot, you are in a 3d view....
“Learning never exhausts the mind.” — Leonardo Da Vinci
7 Posts No Rating |
Sorry, I see that now... Where can I get to a plan view, then?I don't remember seeing it under views...
Go to your "Floor plan"- "Level 1" in the project browser...
Click twice there so the elevation tool will be able to use...
7 Posts No Rating |
Thank you very much, I have it now!! Thanks!!!!!
Elevations, Revit 2013 |
Thu, Aug 21, 2014 at 11:08:25 AM
elevation questions |
Thu, Oct 11, 2012 at 11:05:46 PM
Elevation marks relative to plan zero elevation |
Wed, Oct 17, 2007 at 1:34:16 PM
Selecting Topographic Points based on Elevation |
Tue, Aug 7, 2012 at 3:16:32 PM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Members: | 2017544 | Objects: | 22947 | Forum Posts: | 152209 | Job Listings: | 3 |
