48 Users Online (46 Members):
Forums >> General Discussion >> Revit Project Management >> How do you create a 1"/2 = 1' scaled view ? I'm lost.
23 Posts No Rating |
I already have several views of my Revit Project. I would like to drag a view onto a title sheet. This view should be at the above scale. I made the view black/selected and right clicked. From there I created template view and went into the dialog box. Under custom scale I chose the desire scale and hit ok. I also "applied" the template from the drop down view menu and from the dialog box. When I go to the sheet with the views they do not appear to have changed in size. Frustrating.Could some kind person walk me through the steps. Maybe I am doing it wrong or not doing something. I need only a B&W view. Attached is the view, it came out nice at 100dpi. At a later date I would be nice to know how to install and utilize a HDR file from accustudio. This would preclude me from experimently with studio and daylights. My first priority is getting a scaled view. Thanks and desperate
View scales are set in the view. You can do that seperately in the view or after the view is on the sheet. - To change on the sheet - click on the view, activate it (same as being in the view) and at the bottom of the view, you will see the current sclae. Click on that and change it.
- Or while on the sheet, click on the view, right click and in it's element properties, change the scale there.
Lost View from Sheet |
Thu, Jul 6, 2006 at 6:52:30 PM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Change 0'-0" MAIN LEVEL to 100'-0" |
Tue, Aug 22, 2006 at 7:40:49 PM
Printing without title block and to 1"=100' |
Thu, Dec 8, 2005 at 4:58:39 PM
window opening doesn't show in floor plan view |
Mon, Oct 3, 2005 at 7:59:15 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
