100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> help on rendering revit models in Autodesk VIZ
8 Posts No Rating |
hi everyone, i'm a semi-newbie to revit although i've used it already, i still haven't explored most of its capabilities. however, i was wondering if i could come up with even better rendering output using Autodesk VIZ instead of the built-in accurender. how can you export the finished 3d revit model? i tried exporting it first as an autocad dwg, then opening it from Autodesk VIZ and the normals were all wrong, it just didn't seem to work as seamlessly as i would like. any tips for this one? thanks...
what is the VIZ version you use?? becuase if it viz2005 you export it in dwg and make a file link in viz using the revit preset in the file link manager
Could you tell me what is this VIZ used for? Even I am kinda new to revit, even i would like to improve in Rendering. I use Revit Architecture 2012
viz used to be an "alternative" to the 3dstudio . I think now its 3dmax design, but im not sure, anyways, its an old post you should look for newer ones
VIZ- MAX- all of them- they all have the same rendering motor that
revit has.. you won't render better with any of those- than with revit..
Exporting REVIT 8 Model into Autodesk 3DMax 7 for Rendering |
Wed, Jun 22, 2005 at 9:34:22 AM
Linking the Autodesk Advanced Models Together |
Mon, May 19, 2014 at 2:02:04 PM
Question on Models |
Wed, Nov 23, 2016 at 10:58:42 AM
Render materials OK in AutoDesk 360, not rendering in Revit |
Mon, Nov 24, 2014 at 3:26:41 PM
Compatibility throughout Autodesk |
Wed, Jun 4, 2008 at 10:08:22 AM
Members: | 2022270 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
