Forums >> Revit Building >> Technical Support >> Schedule - share information between
60 Posts No Rating |
Greetings, Is it possible for schedules to share information between each other. thanks
No, but you can include room information in a lot of non-room schedules. What in particular are you after? You always have the options of aligning multiple schedules on a sheet so they "look" like a single schedule.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
I thought this is what Key Scheduling is for? If not, then what's the difference and why?
I am trying to prepare shcudules to reflect General IBC Code information. I have created area plans, room schedules and some key schedules so all the information is there, i just need to group it together. for example one of my schedules calculates the total Occupant Load factor. It would be nice to "call or reference" this information into another schedule that calculates the number of required exits (or even include this in the same schedule). Another example would be to have the user select type of Building it is, if its sprinklered, and present the allowable area. than bring in the current building area as designed to show that this basic criteria has been meet. insanity....
Can't input information into door schedule manually |
Tue, Jan 20, 2009 at 6:12:55 PM
Schedules for Information In Schedules HAHA |
Mon, Feb 13, 2012 at 12:08:13 PM
Scheduling Project Information |
Tue, Sep 25, 2007 at 11:43:04 AM
Scheduling "Project Information" parameters |
Mon, Jun 8, 2015 at 12:36:57 PM
Revit Schedule Problem |
Wed, Oct 22, 2014 at 9:19:14 AM
Members: | 2097950 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
