58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> RAC 2009 dimention text location
Wed, May 13, 2009 at 2:31:47 PM | RAC 2009 dimention text location
JBrent
Greetings:
Is there a way to center dimension text automatically in line centered with the dimension line?   I've been moving the text manually.
Thanks for your help!
JBrent
Wed, May 13, 2009 at 3:14:18 PM | RAC 2009 dimention text location
Not sure what you mean.  The dimension text is centered over the center of the dimension line automatically.  Your options are all set through settings / annotations / dimensions and you can read about these options in your H E L P.
Wed, May 13, 2009 at 3:26:38 PM | RAC 2009 dimension text location
JBrent
Hi WWHub,
Thanks for the reply.
I Mean this: |---------3 5/8"---------|
Revit will easily do this: |________3 5/8"________|  or will allow you to specify an offset above the dimension line, but seemingly won't allow me to specify a negative offset which would lower the text to be centered at the dimension line.
Is that a little clearer?  Thanks for your help
JBrent
Wed, May 13, 2009 at 7:00:42 PM | RAC 2009 dimention text location
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No this is not possible.  As such I would suggest you accept this is the way it is, rather than manually changing them all each time.  That would be a nightmare and significantly impede your productivity.  Add it to the wishlist!
Regards,
Chris.
RAC 2009 - Text in CAD file is not plotting?
Wed, May 27, 2009 at 9:27:51 AM
Imperial Library Location
Wed, Feb 3, 2010 at 7:26:03 PM
Dimention rounding in different views
Fri, Jan 9, 2009 at 6:00:02 AM
RAC 2009 Slow Down - Possible Fix
Sun, Jun 15, 2008 at 8:20:43 AM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:22 PM
31
Page generation time: 1.8841
