112 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Project Templates Transferring
Tue, May 12, 2009 at 3:52:46 PM | Project Templates Transferring
nikolai47
Hello,
Recently, I built a house in revit using the default.rvt default project template only to find out that i needed the Residental-default.rvt project template for the electrical plan view. I dont want to start all over because its a big house and i need time. So is there a way where i can maybe change the project template without copying or starting over? or possibly adding the electrical plan view for three floors?
Please i need your assistance. Thank you
Tue, May 12, 2009 at 5:25:33 PM | Project Templates Transferring
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
  1. Open your project
  2. Open the Residental-default.rvt
  3. In the Project Browser, Right Click on the electrical plan and choose "Create View Template from View"
  4. Name it something appropriate like "Electrical Plans"
  5. OK
  6. Switch to your project
  7. Go to Manage-->Transfer Project Standards (RAC2010)
  8. Choose Check None
  9. Then check "View Templates"
  10. OK
  11. Create a New Floor plan for the view that you want to have an electrical plan of.
  12. Right Click on the view in the project browser
  13. Choose "Apply View Template"
  14. Select "Electrical Plans"
  15. Apply
  16. Done
Hope this helps.  Sounds like a lot of work but its a relatively simple process.
Regards,
Chris.
Transfer Project Standards - 'Filter' colour fills not transferring
Fri, Jun 27, 2008 at 10:12:20 AM
Revit 2015 - Transferring Project Units and Mechanical Settings
Thu, Jan 7, 2016 at 8:12:08 PM
Transferring from project 2 project, and one family Q
Thu, Jul 24, 2008 at 1:48:08 PM
(2010) Transferring filters in View Templates
Sun, Feb 21, 2010 at 7:11:45 PM
Extracting families from a file for future use in other files
Sat, Mar 19, 2011 at 2:26:31 PM
Page generation time: 19.4814
