69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> roof edges
Mon, May 11, 2009 at 7:54:41 PM | roof edges
greg1970
Im having issues with pitched roof edges.  We do traditional architecture and when we show a gabled roof edge we ony want to show the flashing sometimes - say 4", but when I make a roof with a 12" rafter + the 5/8" sheathing I get all 12 5/8" showing on the edge of the building in elevation.
 How can I get the roof to extend up to within 4" of the roof top even though the thickness of the roof family is 12 5/8"?
Mon, May 11, 2009 at 11:01:50 PM | roof edges
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If I understand correctly:
  1. Go to your roof instance properties,
  2. In Construction section change the Rafter Cut to "Two Cut - Plumb"
  3. Set the Fascia Depth to 4"
  4. Select OK
This should give you the desired result.
HTH.
Regards,
Chris.
Tue, May 12, 2009 at 7:38:14 AM | roof edges
greg1970
this only helps with the eave side of the roof not the gable end.  The gable end is still full height.
Tue, May 12, 2009 at 8:09:28 AM | roof edges
mathill
I just do two roofs-
1 the right visual thickness on top and overhanging the walls,
2 sitting under and in between the walls the right construction thickness.
otherwise i guess you could use some kind of edge profile
Tue, May 12, 2009 at 5:12:16 PM | roof edges
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We'll typically model the framing and our roof normally just consists of sheeting (and sometimes furring channels)
Regards,
Chris.
Pitch roof problems- double-plumb roofs with different height edges
Thu, Feb 21, 2008 at 2:54:47 PM
Profile Sweep over Roof Cricket [ 1 2 ]
Fri, Sep 7, 2012 at 12:47:32 PM
27
Curved Roof with tapered edges?
Wed, Sep 1, 2010 at 4:28:16 AM
Curb & Sidewalk Sweeps that could be attached to site topo edges! Why not?
Wed, Apr 19, 2006 at 9:17:08 AM
Shed Roof - drip edges - how to join at flat edge and angled edges??
Thu, Oct 19, 2017 at 1:38:40 PM
Page generation time: 0.4876
