78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exterior walls not visable
Mon, May 11, 2009 at 5:15:53 PM | Exterior walls not visable
sloman
For some reason in our second floor rcp, our exterior walls aren't visable.  I've narrowed it down to some error with the workset.  I took an interior wall (which was visable) and changed it from the InteriorSecond workset to the Exterior workset and it disappeared from the rcp.  The workset is turned on for this view and the windows which are also on the exterior workset are visable...just not the walls for some reason.  The first rcp is working fine and I can't see any difference in how it is set up.  I also tried changing the crop view before I realized that it had something to do with the workset.  All to no avail.  The walls are visable in all other sections, plans, etc.  It is just this one view that they are missing from.  Any ideas?  I'm completely stumped!
Mon, May 11, 2009 at 5:28:24 PM | Exterior walls not visable
sloman
Nevermind!  We finally found that a filter had somehow been created.  No one knows why or how it got there, but somehow it was created, causing our problem.
RECESSED PANELS IN EXTERIOR WALLS
Mon, Oct 31, 2005 at 4:22:38 PM
Exterior Bearing Walls?
Tue, Jan 22, 2008 at 8:46:41 AM
Exterior Windows elevation
Sun, Aug 26, 2012 at 5:26:58 AM
12
revit 2013 exterior walls not showing correct
Wed, Jun 12, 2013 at 3:46:09 PM
Walls keep moving
Fri, Apr 11, 2008 at 10:04:18 AM
Page generation time: 0.6393
