88 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Ramps unaffected by cutplane setting?
16 Posts No Rating |
Hi all,
I'm drawing up a multi-storey carpark building but for some reason my cutplane setting has no effect on the vehicle ramps.
Am I doing something wrong or is this a bit of a bug in Revit?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
If your using the ramp tool then yes this is a bug in revit... In most cases i end up using a filled region in plan for ramps as they tend to display transparent in most cases...
Thanks for that!
Yes, I was using the ramp tool. I'll try out the filled region method.
Cheers.
![jhudtwalcker Avatar](user_avatar/20008.jpg)
7 Posts No Rating |
but... what happend if you have something under the ramp? lets say... some parking spaces? If I use a masking regions, I wouldn't see those objects... would I?
Attach Walls to Ramps |
Fri, Feb 18, 2011 at 6:45:16 AM
Showing break lines with Ramps and Stairs |
Mon, Jul 30, 2018 at 11:02:36 AM
Windows above the Cutplane and Symbolic Lines (Revit2010) |
Wed, Jul 14, 2010 at 7:35:42 AM
TYPE SELECTOR for ramps and stairs |
Thu, May 3, 2007 at 2:46:53 AM
Ramps, What are they good for? Absolutely nothing |
Tue, Dec 6, 2011 at 9:57:51 AM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
