17 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 Spline restriction
Ok I am trying to see if revit 2010 new modelling can do certain objectives. I am sure many of you would have heard of UN studio the mobius strip. http://en.wikipedia.org/wiki/M%C3%B6bius_strip I am trying to do a continuous spline but will not join at both ends which is annoying to carry out a sweep to replicate a mobius strip sweep . I wanted to see if anyone had some time to try out these new tools to see if there is a better solution. here is a screen shot of what Im trying to do
If symmetrical, make one, copy/mirror and join geometry.
Motto: "No Post left behind" |
This is a known issue that a spline cannot be fully enclosed in a single section. I'd imagine this could only be acheived in sections merged together or mirrored/copied as already suggested. We may have a better concept modelling tool but there are still a few limitations mainly bound by "unable to create geometry" and "would result in self-intersection geometry"... Oh how I wish it would just let me create the self intersecting geometry and I'll deal with the issues later...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Thanks for the feedback guys I did read this earlier just had no time to reply. Its a shame it is still quite restrictive although its a great modelling improvement. Im going to use rhino with revit for now till revit improves in the modelling department a little further. Is it possible that due to this improved modelling with revit would help importing rhino to revit. I import rhino into revit using family mass. I know if I had to many faces when importing from 3ds max or rhino it wouldnt compute the volumes of the forms imported.
spline with two heights? |
Tue, May 12, 2015 at 8:08:32 AM
Annotation the Radii of a spline? |
Fri, Apr 23, 2010 at 9:53:44 PM
Spline from AutoCAD to Revit |
Tue, Mar 24, 2009 at 5:16:38 PM
How to make closed spline |
Wed, Jul 20, 2016 at 8:41:23 AM
associative spline |
Fri, Nov 7, 2008 at 7:47:39 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
