24 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> 3 Point Sloped Roof Deck
1 Posts No Rating |
I'm trying to slope a triangular shaped roof with one point as a high point and the two other points at a lower point at the same elevation. I've tried to the conventional way of modeling with the slope line the sketch mode, but it still looks awkward. Is there a way to set each side to elevations? Or how would you guys suggest I model this roof?
When you do your sketch, only set the one leg as slope defining ... should work fine.
Metal roof deck on sloped roof |
Wed, Oct 21, 2009 at 3:33:17 PM
Roof to follow sloped structural steel |
Wed, Sep 22, 2010 at 4:11:16 AM
Sloping joists to the roof deck |
Mon, Apr 4, 2016 at 11:21:15 AM
adding crickets to a sloped roof structure |
Mon, Oct 16, 2017 at 9:28:29 AM
slope metal roof deck |
Thu, Jul 21, 2011 at 9:40:39 AM
Members: | 2017941 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
