71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Color Legend Disappears
Mon, May 11, 2009 at 11:18:16 AM | Color Legend Disappears
mark2001
I noticed that when I fill in room areas and drag in a color legend and go to another plan and come back to the plan I drew the legend in everything stays.  But if I want to use the area boundary tool and place tags and then place a legend and go to another plan EVERYTHING DISAPPEARS.  Anyone know what I am doing wrong.  I want to color coat units that have multiple closed rooms in them (which is why I am using the area boundary tool)
Thanks
Mon, May 11, 2009 at 6:19:58 PM | Color Legend Disappears
mhans
3 Stars: 10 Votes
RAC 2010 or 2009?
Motto: "No Post left behind"
Tue, May 12, 2009 at 1:25:36 AM | Color Legend Disappears
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Area lines are model elements, sounds like you may be duplicating your area plan to create a new one and then modifying all the boundaries and going back to you previous to find its changed?  Am I correct?
Area boundary lines below to particular Area Schemes.  If you need to create a different type of area plan on the same level then you need to create a new area scheme and apply your view to that particular scheme.
HTH.
Regards,
Chris.
Fri, May 15, 2009 at 10:31:13 AM | Color Legend Disappears
mark2001
I am still scratching my head on this one.  I will get back to you after I have read more.
Lines color legend
Tue, Dec 24, 2013 at 9:36:24 AM
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Can I have all my areas on drawing but only few values on Color fill legend?
Tue, Oct 30, 2018 at 7:32:26 AM
Area Legend not showing
Fri, Mar 14, 2014 at 1:00:17 PM
color fill legend dosent show all the types/colors
Fri, Sep 11, 2009 at 12:45:28 PM
Page generation time: 0.3669
