30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Structure
Mon, May 11, 2009 at 11:01:54 AM | Wall Structure
RainaMc
RainaMc Avatar
Hello all.  I am still working in revit 2008 doing Residential Architecture.
Just curious how most set up wall structure.  I worked in AutoCad previously and only showed the 2x framed wall.  In Revit the wall is set up to show the framed wall, sheathing, interior, and exterior finishes all with a thickness.  However this seems to confuse the builder and the structural engineer.  So I am just wondering if anyone out there has maybe continued to show the framed wall and applied a material still to show siding but not included the other building materials that make up a wall in the real world?  Would there be anything wrong with doing it that way?
Thanks in advance,
Raina Mc
Mon, May 11, 2009 at 2:10:04 PM | Wall Structure
tim123
4 Stars: 19 Votes
I would suggest that you do it the way that works best for you.  You could create the structure and external finish as one wall and the internal finishes as a separate wall, joined to the structural wall.  Alternatively, use a repeating detail in the structural zone to show the framing and hide the wall for those drawings.
I do find it strange that consultants and builders get confused by seeing things as they actually are, provided that the dimensions are to the structural zone.
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
snapping to wall structure
Thu, Apr 10, 2008 at 3:35:37 PM
Wall structure
Thu, Dec 8, 2011 at 1:02:34 PM
Wall Finishing Material (& structure) in just one Tag
Fri, Aug 21, 2015 at 6:16:21 AM
Schedule of structure of wall
Wed, May 19, 2010 at 1:39:45 AM
Page generation time: 1.9715
