24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> plan view range
Mon, May 11, 2009 at 9:56:42 AM | plan view range
jprado
i realize this is probably one of the most asked questions but can't find an answer thread:  my project has an existing floor (6th fl exist) and a new floor built 8" above over most of the existing (6th fl).  I have tried to manipulate the view range and underlay options for both 6th fl exist and 6th fl but my plan still looks like the attached.  In general, i can't yet understand views.
Mon, May 11, 2009 at 10:10:13 AM | plan view range
Do you really want an underlay on?  If your view is set to your new floor level, you can increase the view depth to the old floor level to show that.
You may also want to experiment with plan regions.  Look in your HELP to understand those.
Mon, May 11, 2009 at 10:26:22 AM | plan view range
jprado
I can't understand why the floor continues to show through walls, fixtures, everything.  I have turned off underlays for these two levels and set the bottom and depth of view range to 0".  Nothing I do seems to affect the view.  Perhaps it's a Vista thing, but my help crashes every other time I use it.  Is there a reason why the floor would show through the walls built on it?
Mon, May 11, 2009 at 10:42:12 AM | plan view range
If the walls on the lower floor are set to goto the level above, then they will show up because you set them up that way!  They either have to goto the bottom of the floor by using an offset or edit the floor - changing it slightly then when you finish editing, let REVIT cut out the portions of the walls that the floor intersects.
Mon, May 11, 2009 at 10:57:37 AM | plan view range
jprado
That makes sense, but all the interior partitions in the 6th flr plan screen shot i posted are walls built on the new 6th floor.  I created one large floor.  All interior partitions are built on that floor.  There are no interior partitions built from the existing 6th floor beneath the new 6th floor.  I'm still searching the help with little success.  Thanks for your help.
Mon, May 11, 2009 at 12:11:21 PM | plan view range
jprado
So now i have redrawn the floor in sketch to trace along the face of walls and I have deleted the exist floor and created floors only where it is visible from the new floor plan.  This is retarded but i can't get any information on floor regions because my help crashes, thanks to VISTA.  The sections are now ruined but, hey, fight your battles as they come. ;^)  Can anyone give me a clue?
Mon, May 11, 2009 at 1:49:17 PM | plan view range
jprado
Mon, May 11, 2009 at 4:34:26 PM | plan view range
jprado
thanks to everyone.  someone had set model to wireframe and didn't catch it.  thanks again.
view range on uderlay inconsistant with view range of plan view
Thu, Sep 4, 2008 at 3:48:11 PM
Plan Range - displayingn duplicated views
Wed, Aug 1, 2007 at 8:45:02 AM
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
Plan cuts incorrectly at windows despite correct view range
Thu, Aug 6, 2009 at 9:12:23 PM
plan region/view range window
Mon, Feb 9, 2009 at 4:39:34 PM
Page generation time: 1.3485
