76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit Architecture 2009 Artlantis 2.0 Exporter - problem with toposurfaces
Mon, May 11, 2009 at 2:29:14 AM | Revit Architecture 2009 Artlantis 2.0 Exporter - problem with toposurfaces
411toaster
Hi all,
 I am typically an archicad + Artlantis user, but i have been working with revit lately and am loving it!
 Problem:
I have got the latest exporter from artlantis.com and it works well with everything except the topo surface... the material of it comes out as just one material. I guess because this is seen as a single surface ??
 I am a novice at Revit so you'll have to excuse me.
Is there a way to explode it maybe, so artlantis assigns materials to the subregions?
Mon, May 11, 2009 at 2:43:41 AM | Revit Architecture 2009 Artlantis 2.0 Exporter - problem with toposurfaces
411toaster
Just to be clearer, the topo suface I have has several subregions (grass areas) and roads (asphalt areas)
and this does not show up in artlantis. I.e. artlantis only sees it as a single material and not grass/asphalt/bark areas.
Cheers very much
Thu, Nov 20, 2014 at 12:30:50 PM | Revit Architecture 2009 Artlantis 2.0 Exporter - problem with toposurfaces
anhedrogin2
Man, i have the same problem, it just sucks !, anybody can help us ????
Artlantis 6.5 for Revit has arrived!
Wed, Feb 1, 2017 at 10:48:31 AM
Can you tell a building pad to cut multiple toposurfaces? Revit 2014
Tue, Aug 12, 2014 at 2:45:16 AM
Export from Revit 2009 32 and 64 bit to Atlantis 2 available
Tue, Apr 21, 2009 at 12:59:52 PM
Revit Building 9.1/Artlantis
Thu, Apr 16, 2009 at 3:10:05 AM
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
Page generation time: 16.5553
