Forums >> Revit Building >> Technical Support >> Call outs withing call outs
49 Posts No Rating |
Is it possilble to do a call out from say a wall section, detail that call out, then do another call out of that detail and carry over the detail lines drawing into that call out. I try to do this but my detail lines do not carry over to the final call out.
I don't know if this is what you are trying to do but Create a Callout of a section view, change what you want, then duplicate that callout with detail, dependant... whatever...
Detail lines and components will always copy / paste same place in either direction of the same relative view.
what im trying to do is do a callout from a bulilding section (1/8"=1'-0" to a detail of 1"=1'-0". I want to add detail lines and components like window heads, blocking, detail lines, etc. From there I want to do another callout form the 1" detail to a 3"=1'-0" detail, but I dont want to copy paste, I want the info I added to the 1" detail to carry over, so that if I make a change at the 1" detail level it will update the 3" detail. For instance, if I move the window head 1" to the left in the 1"=1'-0" detail it will automatically move int he 3" detail.
You can create a dependant view with a different scale that will have the same detail and will update the information.
Call outs in Revit |
Wed, Jun 11, 2008 at 8:39:24 AM
Call Outs |
Sat, Feb 27, 2010 at 5:23:34 AM
Strucutral Columns VS Walls in Call outs |
Mon, Aug 16, 2010 at 8:17:06 AM
Elevation call outs missing |
Thu, Apr 3, 2008 at 8:35:14 PM
Changing options on call out views so able to see on all floors |
Thu, Oct 29, 2009 at 6:33:52 AM
Members: | 2099063 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
