70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Quoin stack
Sat, May 9, 2009 at 5:21:43 PM | Quoin stack
ad330coupe
Has anybody used the quoin stack in revit structure 2009, the family is available to load but does not work as expected, looking for some advice on how to use it, i believe its in the detailed components folder under quoin stack.
Cheers
Sun, May 10, 2009 at 4:00:38 AM | Quoin stack
ad330coupe
Ok, its actually located in the generic model folder in the metric library under quoin stone, when starting a blank project and using it i can get it to work fine, but in this project it seems to muck up, see attached photo...
Sun, May 10, 2009 at 4:48:57 AM | Quoin stack
4 Stars: 203 Votes
The family it work fine, delete that and insert again, select one wall then you can adjust the position in plan, elevation view...
Sun, May 10, 2009 at 4:07:14 PM | Quoin stack
ad330coupe
Thanks, I can get it to work in new projects but not this one, is there something wrong in the project? What could be causing this? Thanks
Sun, May 10, 2009 at 4:36:02 PM | Quoin stack
4 Stars: 203 Votes
I don't know, only "seeing" the file....
Sun, May 10, 2009 at 4:44:28 PM | Quoin stack
ad330coupe
would i be able to email you the file for you to look at?
quoin stack in Revitr2008
Tue, Sep 25, 2007 at 7:44:27 AM
Quoin corners
Thu, Feb 22, 2007 at 8:40:16 AM
Stack Wall Problem
Thu, Jun 4, 2009 at 3:17:56 PM
More stack wall problems!
Sun, Apr 8, 2007 at 3:40:16 PM
Stack Wall Problems!
Wed, Feb 14, 2007 at 2:52:29 PM
Page generation time: 0.2160
