Forums >> Revit Structure >> Technical Support >> Revit 2010 UI Missing Command
Has anybody noticed the Creating new 3d views oriented to other views is not there anymore? Am not sure what's happening with the new interface but there not much concrete or discernible improvement apart from requiring us the users to adopt and relearn a new system. Is there any good coming out of this? I thought the better system would be to give us the option to ease up to the new UI while enabling us to work with the "classic interface" in the meantime and get us into our production work. Autocad have these options why not Revit? All this is looking like a Microsoft style of simple and friendly user interface design. As the NYTimes reviewer asked " Why in the hell would any UI designer use the "Start Button" to terminate and exit Windows".
Hi, On any 3d view and with the "cube" on. Right click on the cube and you'll see the orient to view option.Take the new UI more of a challege than an obstacle. It's a pain and the sad thing is Autodesk seems deaf to our wishes. Oh, Well!
Motto: "No Post left behind" |
Thanks mate. I did found it after so much hunting. Anyway, Are you aware of the additional command you get by putting in a line in the ini file: [Construction]AllowSplitwithGap=1 in 2009, That doesn't seem to work in 2010....or does it? I do like the ribbon concept but like any thing new we need to invest some time getting used to it. Problem is wth Revit once you start working on a job with the new version theres no reverting back temporarily or otherwise. 2009 had some really good improvements contentwise over 2008, this version is a disappointment.
No, haven't tried messing around with ini of 2010. Have you been watching TV lately? There's a phrase that fits REVIT and all it's previous releases - "but wait, there's more!"
ha..ha.. YEAH RIGHT That qualifies as a TUI Beer billboard commercial we have here.....
"This is the best Revit release ever..........YEAH RIGHT."
2 Posts No Rating |
Check out the link below; its designed to help you find moved commands in revit 2010 through revit 09. not perfect but pretty helpful. http://www.nichitecture.com/downloads/Where%20is%20my%20command%20in%20Revit%20Architecture%202010.html
revit 2010 provies a wheres my command function within the program... seriously its not that difficult
2 Posts No Rating |
"revit 2010 provies a wheres my command function within the program... seriously its not that difficult" just another option; the 2010 function wasnt mentioned. my assumption is this person didnt know about it, nor did I so thanks for the heads up.
