85 Users Online (84 Members):
Forums >> General Discussion >> Wishlist >> View/ Interior Elevation Legend
5 Posts No Rating |
I'm finding that since the elevation tags are uneditable system families, I can't change them to mimick what every office standard I've seen has been, essentially on detail per room (ie 1/A4.01) with four sub details labeled "A", "B", "C" and "D". I think what Autodesk needs to do is make an entirely new category for interior elevations. Make a seperate "Legend" type interface in which the user can drop all associated interior elevations from one room into it and then place that on a sheet as a group. The Callout on the sheet should then look like a combination of the Section Head and the Elevation Tag. With the interior portion calling out the view reference and sheet number( The 1/A4.01), while the elevation tags at the end of each arrow would reference the individual sub views (the A,B,C and D).
![3 Stars: 10 Votes](/images/stars_3.gif) |
Is this what you mean?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
My Blog explains how to achieve what mhans shows. But yes it is a long standing wishlist item. Since v3/4 ish!
Regards,
Chris.
Want to have typical washroom elevation on multiple sheets |
Fri, Oct 23, 2015 at 11:20:00 AM
Can I call out from a legend view |
Thu, Oct 15, 2015 at 10:57:52 AM
Interior Elevation Tags |
Wed, Oct 9, 2013 at 2:23:36 PM
Can Interior elevation view box not be a square? |
Fri, Jun 10, 2011 at 12:52:29 PM
CAD import disappears in interior elevation |
Fri, Dec 6, 2019 at 12:40:46 PM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
