Forums >> Revit Structure >> Technical Support >> Schedule !!!!
i have scheduled up all my columns and in the schedule fields i have the ''type'' and ''count'' selected. my question is, is there a field or a way to show the location on grid of the column i,e gridline A,1 or gridline K,10........ if there is it would be very helpful with the job i am working on at the moment. cheers
That would be nice for you structural guys but at this time, I don't see how. You could add a location parameter (instance) that you fill in. Architecturally, we can identify where objects occur in rooms because there is a defined 3D volumn that REVIT can associate with. You would think that they could build in an association to grids that you could turn on/off. See next post.
Edited on: Fri, May 8, 2009 at 8:12:36 AM
Wow - In 2010 Architecture, you can schedule the column location if you placed them by grid...! Not being structural, I had not tried this. Could you do this on earlier versions? For those columns off the grid, it even gives you the distance from the grids.
Edited on: Fri, May 8, 2009 at 8:12:08 AM
Schedule material mark in door schedule - Revit 2014 |
Fri, Jan 19, 2018 at 2:57:04 PM
window schedule - skylights |
Wed, Jun 7, 2006 at 10:00:03 AM
Running a Schedule |
Thu, Mar 15, 2012 at 7:21:18 AM
Multi-building Schedule |
Mon, Jun 9, 2008 at 3:43:32 PM
Light and Vent Schedule |
Tue, Jan 18, 2005 at 11:40:30 AM
Members: | 2115479 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
