Forums >> Revit Building >> Technical Support >> Loading Curtain Wall Door Types
1 Posts No Rating |
Ok this is driving me nuts. I think I understand how to place a curtain wall door, just from all the posts on here, and from the Help screen in Revit, but what I am havig an issue with is LOADING the stinkin things! I can not for the life of me get it to load. I know exatly where it is, and when i am in my Door command and hit "Load" like I do every other time I want to load a door, I go in, choose the folder then the file and hit OK, and then it goes out of the dialogue box and NOTHING HAPPENS!! There is no curtain wall door in the drop down menu! I tried it in Windows and in Components. I REALLY REALLY REALLY want to put a door in my curtain wall. I have tried it several times (know what the definition of insanity is?) and it still won't work. WHAT AM I DOING WRONG?!
In that curtain wall, with the "TAB" key click until you select the panel you want, then go the properties and "Edit", in the "Curtain Panel" select your "Door", REMEMBER the "door" should be created in "Curtain Wall - Doors" family....
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
Cant load Curtain Wall Door |
Wed, Oct 26, 2011 at 3:41:44 PM
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
Members: | 2105004 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
