77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Masking Regions in Symbols not working
Thu, May 7, 2009 at 5:25:15 PM | Masking Regions in Symbols not working
ArcHaus
Hey everyone,
I have created an annotation (symbol) family with text and a linework box around the text. When I insert the symbol in a view (over the building - see attached jpg) the text is opaque and therefore 'blocks' out the building behind, but the linework box doesn't stand out amongst the other lines of the building.
I figure I could use a masking region instead of the linework box, but it doesn't mask out my building (i.e. create a solid white box with text in it).
I can't set the work plane of the masking region either....therefore what is the point of having masking regions in annotation families - they don't mask anything!!!
I am using Revit 2009.
Thanks
Thu, May 7, 2009 at 5:47:01 PM | Masking Regions in Symbols not working
ArcHaus
Actually - don't worry!
I re-inserted the symbol and it worked!....I take it all back, masking regions in Symbols are great!
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:23 PM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:56 PM
Quick Help Needed - Masking Regions
Fri, Jan 25, 2013 at 2:54:48 PM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:28 AM
11
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:35 PM
Page generation time: 0.4785
