47 Users Online (45 Members):
Forums >> Revit Structure >> Technical Support >> Color Schemes - Revit 2009
60 Posts No Rating |
I am struggling with these color schemes. I would like to have the Area of the rooms show up in the legend of the attached image. This is a simple little code plan that shows the mix used occupancy of a building. It would be nice if the tone also went into the stair area in the lower left corner. I have read and re-read the darn help file in Revit, but alas I am not getting it. Any help would be greatly appreciated. thanks j
Simply edit your area sketch to include the stair.
Area sketch does include the stair. thanks j
Revit only knows what you tell it. For areas, it uses the area boundry lines - not the model. If there are area lines outside your stair then you also have area lines between your stair and the red area. Remove those.
Thats what I kept thinking too. The answer is really kinda strange (at least this fixed the problem). That area where the tone or shade did not appear had a concrete floor with a solid fill surface pattern. When I change it to be a concrete surface pattern, the area fill worked fine. Now if I can just figure out these darn legends. I am trying to make a couple of Life Safety plans that show areas, and I am trying to get the Area to show in the legend along with the name. thanks for you help j
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:35 PM
area color schemes |
Fri, Jan 27, 2012 at 12:07:13 PM
Color Schemes |
Wed, Jun 3, 2015 at 3:15:18 PM
"System Color Schemes" not regular color schemes in Elevation or Section views |
Mon, Mar 22, 2010 at 6:00:00 PM
Color Schemes |
Thu, May 23, 2013 at 12:35:43 PM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
