145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> hatch scale?
Thu, May 7, 2009 at 2:22:50 PM | hatch scale?
barcardi
So i am working on this site at 1/60th inch, i want to hatch a small portion of a building roof.  Right now the hatch pattern is much too large, is there any way to scale just the hatch without changing my drawing scale?
Thu, May 7, 2009 at 2:23:45 PM | hatch scale?
barcardi
forgot to add, im in 2010
Thu, May 7, 2009 at 2:50:59 PM | hatch scale?
You need a new hatch.  If you have the old hatch file (pat) file, re-import it at a new scale.
Fri, May 8, 2009 at 1:53:36 PM | hatch scale?
barcardi
how do i go about doing that
Fri, May 8, 2009 at 2:29:46 PM | hatch scale?
4 Stars: 202 Votes
Go to the materials or properties of that roof and follow the image attached....
Fri, May 8, 2009 at 5:13:40 PM | hatch scale?
millerg
Hey! Thanks for this question becaue mine is similar. I have a metal roof and want a hatch pattern to show the seams. This works well in elevation, but will not ""orient to view" in 3D. The 3 options for the Orientation are "Orient to view", "Keep readable", and "Align with element"... but none will make the lines follow the slope of the roof in 3D. Any solutionS?? Thanks so much for all the help I get from this site!!! Miller
Miller Graves
Residential Design and Drafting
Asheville, North Carolina
millergraves@gmail.com
Sun, May 10, 2009 at 7:42:35 AM | hatch scale?
If your hatch is a model hatch and is associated with the material, you can rotate the hatch to match yor roof.
However, your post sound like you hatched a view.  That has no relation to the model.  Assign the hatch to the material.
Sun, May 10, 2009 at 9:15:59 AM | hatch scale?
millerg
Yes... it is a model hatch.  It is assigned to the material "metal roofing", via the same "structure" tab in the type properties > edit assembly dialogue box. My "metall SS" hatch is a "simple" hatch that I created using verticle parallel lines. So... per your answer... how do I rotate it? I thought it would rotate itself 90 degrees to the line of the wall plate??... or orient to view accordingly as needed for a 3D view??
Miller Graves
Sun, May 10, 2009 at 3:33:48 PM | hatch scale?
tim123
4 Stars: 19 Votes
If its a model pattern assigned to the material then it will align in all views.  You can rotate it by selecting one of the lines (use tab) and rotate it.  You cannot align a model pattern to the view so I assume that your pattern is a drafting pattern and not a model pattern.
Can I change Structural member hatch scale, rotation??
Thu, Jan 26, 2012 at 6:18:19 AM
Hatch Pattern Scale Factor
Tue, Jun 17, 2008 at 12:36:30 PM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:36 PM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:32 PM
Hatch Patter - Fish Scale
Tue, Nov 17, 2015 at 10:54:34 AM
Page generation time: 1.1600
