134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Site Sub Region Surface Pattern
Thu, May 7, 2009 at 12:20:42 PM | Site Sub Region Surface Pattern
everist
3 Stars: 2 Votes
Is it possible to apply a surface pattern to a site sub region? You can apply a material to a sub region, but the surface pattern of the sub region does not show up. Am I missing something?
Thu, May 7, 2009 at 1:23:34 PM | Site Sub Region Surface Pattern
4 Stars: 202 Votes
Even in 2010 you can't, did you see the warning??? If you want in a "plan view" create some area with a surface pattern you can use the "Filled Region" with the appropriate "hatch" but this only appear in that view because like you should know it's a 2D element.... Don't solve the problem in 3D view but come one, your plan views (site and so one) looks ok...
Edited on: Thu, May 7, 2009 at 3:36:36 PM
Filled Region Not covering wall surface pattern
Mon, Apr 25, 2022 at 8:09:10 AM
SPLIT SURFACE and GRADE REGION
Thu, Sep 15, 2005 at 7:54:25 PM
'Surface Pattern' and corresponding 'Region Fill' appear differently.
Fri, May 17, 2013 at 9:11:55 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:02 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:34 AM
19
Page generation time: 0.6707
